front end bushings
the1andonlyGR81
State of Confusion
i was doing my brakes when i noticed my passenger side wheel was moving back and forth about 2". had the front end put together with brand new moog bushings and found this......
absolutely no busshing in the front!so now as i say always doing something
That is a common problem with the MOOG SRBs... Go order Motorcraft bushings and you will most likely never have to screw with them again as long as you own your car.
Yup, i'm gonna be replacing mine with motorcraft parts. I've heard numerous threads about the moog or rather any aftermarket SRBs. There is almost no price difference between the two parts. Getting mine done monday.
The only reason I ask is because as far as many people can tell you can only buy the ford bushings. Not the full kit with bolt, washers, and inner sleeves. You may be forced to track down used hardware or buy Doug's sleeves.
Hmmm...gonna be doing mine next summer, I better check with the dealer now and see what they have. The washers and bolts I have, the inner sleeves I can make if I have to.
