Reg unleaded
Blueberryyum02
Griffen
Quick question I filled up with reg unleaded, by mistake is this good or bad I noticed that car runs good if not. Better then using 93 I haven't felt any loss in performance no knock nothing is this good. Or should I put a octane booster in.
Im not an authority on this but I believe it may just affect the efficiency of the engine. Lower mpg. But my dad uses regular. I prefer premium. But he's used regular since owning his last fall. No issues yet
I think it's crazy to put regular but thats just me.
I believe it says 91+ on the gas cap for a reason.....
My Gen I would ping if I accidentally put regular in. Could have been the tune... My understanding is that there is a knock sensor that will reduce HP if it starts pinging due to low octane...
and i though i had a bad day when i accidentally put a tank full of premium into my DD cavalier
If it doesn't ping don't worry about it. If it does, drive it easy. Either way, drive it until the tank is empty and refill with premium. Problem solved.
Always premium. It doesn't say 91 on the gas lid to sell you more expensive gas. Its there for a reason. I put a tank of regular in my 2000 once and it wouldn't idle at a stop.
regular gas may cost less now but it will cost you more in the long run with decreased mpg and increased breakdown of a multitude of different components and sensors. the effects may be subtle at first, but your car will definitely not run as wel over a period of time. not recommended.
i would fill with higher octane asap; 1/2 tank of 87 + 1/2 tank 93 shot into the tank with most gas nozzles will mix it well enough that you will end up with what is essentially 90 octane...
Ha. Just like I get yelled at when I accidentally put premium in my company vehicle. It happens once about every three years and I get yelled at every time like I do it all the time. LOL
Why is it so hard to use the right octane?
And why do people bitch about an extra $3.50 a tank but go spend $5 on coffee a starbucks daily?
Also, the reduction in their mileage is likely to cost them more per tank than $3.50 anyway.
Probly the same people who drive to 3 different grocery stores chasing sales that save them $3 total
Ah yes, the monthly gas thread.
I accidentally filled my tank with sand. It is still running okay, so I may continue the sand trend.
I accidentally filled my tank with my neighbors gas... It's been running fine, I think i'll continue that trend too.
I purposely filled my tank with 91 octane gasoline and it is running great, so I am going to continue that trend.
I've made the mistake a time or two. Not every station puts the low octane button on the left and the high octane on the right. The stations do this (in my opinion) to get the folks who push the 87 button without looking to buy the more expensive gas so they can make more money from those that don't pay attention.
The point is, the man came to see if there was anything to worry about due to his buying a tank of the wrong octane by mistake and he's being dinged as though he were a cheapskate who routinely buys 87 for his LS. The car can handle 87 octane for a single tank without damage. If it pings, drive it easy until the tank is gone. When the tank is gone, refill with 91/93 octane and drive on.
the real question here should be: 91 is not as widely available as 93, is 93 burning all the way through and not being wasted?
I've been gotten by this old trick once, I almost missile drop kicked through the little window slider at the manager :mad:
that is not how octane rating works.
the higher the octane rating, the more pressure it takes for the mix to ignite on its own, without spark.
with a motor with a high compression ratio, you dont want the fuel to ignite too soon on it own (boom)
there is not "extra fuel" left over in 93, the computer would read this, and adjust the mix.
@Blueberryyum02
1LoudLS has made it clear WHY there is different grades.
Ill further Explain:
WHAT GASOLINE IS MADE UP OF AND HOW IT WORKS:
Gasoline is made up of 2 parts totaling 100%, 3rd part additives/dilution.
Initially after purification, we wound up with two major components for burn: Heptane, and Octane. Octane combusts with ignition, i.e. spark. Whereas Heptane combusts with compression. Octane burns hotter than Heptane, so ideally it is more desired for fuel source than Heptane.
Now, when you see at the pump "93" and as well, "89", the percentage here applies as follows:
"93" is the percent of Octane. The remainder to make up 100%, is Heptane, which in this case is "9%"
Likewise with "89", remainder being 11% Heptane.
Those percentages are BEFORE the additives the gasoline companies introduce. Like Shell and the "Nitrogen enhanced" and so forth.
Combustion engines Run on these two critical elements: Combustion and explosion, and therefore the balance between octane and Heptane is CRITICAL when engineering a motor because, Too much Heptane and the ignition can happen too early, like before the spark. Too much octane, and the spark happens BEFORE the desired compression.
The idea here is that as the Piston compresses the fuel - air mix, You want the Heptane to ignite at the exact same moment the spark ignites the Octane. The result is a complete Burn of both products, maximizing Efficiency and harnessing all the power from that explosion.
If the explosion is too early, or opposite, too late, The piston either shoots down early/late, resulting in unwanted tension on your crankshaft, and connecting rods.
Wrong fuel grades can have results such as engine noise like knocking and pinging. Essentially, these noises are the product of mistimed explosions in the engine, the result of wrong grade of fuel put into the vehicle. Even if you don't hear those noises, its still slightly mistimed, and not healthy for your car. you could be adding strain to your internals of your motor which is what makes those sounds.
HOW TO KNOW WHAT FUEL TO PUT::
When you fill your gas, majority of vehicles have the Fuel grades on the inside of the gas cover.
They very, reading Different numbers. i.e. 87, 91, 89, 93, 89+, 91+
Some have this '+' next to the octane number. This is because the motor is designed to accommodate octane percentages higher than the number listed. So 89 + would mean You can put 89, 91, or even 93. however, given the number listed is 89, you cannot put less than 89% octane, according to the manufacturer.
If the Gas cap says "89" without plus, you shouldn't put anything higher or lower. Just put 89. That is what the manufacturer has called for.
If you accidentally put too low of an octane, you can always add "OCTANE BOOSTER" which is found and your local automotive store or Canadian Tire... if your in Canada..
If you accidentally put too high, you can try adding lower grade to dilute. As long as you dont hear knocking or pinging you should be ok.
One Final note:
Some believe that the different grades of octane are there primarily because 93 burns better and cleaner than 89, or 87. Therefore always best to put 93+
Others believe its a hoax from the gas companies, just to charge us extra.
These are myths, our fathers and forefathers believed. The Older generations who think they know everything
I hope this Helps!!
Lol you guys hold no punches, no mercy at all I love it. As much as I wouldn't mind being a cheapskate, I just can't. Dropped a octane booster in, and waiting for the gas to run out, but it's funny I checked my mpg yesterday and it's actually doing better, I was getting 16 cause I stay in a housing community with a steep incline to get out to the main road, and sadly enough im at the very bottom of the cummunity, now I'm actually getting 18 + go figure.
Lol I guess these guys read the title and went blind to what I was asking, thanks to those who helped and lol to those who started off the bat, riding, about it.
... but it's funny I checked my mpg yesterday and it's actually doing better, I was getting 16 cause I stay in a housing community with a steep incline to get out to the main road, and sadly enough im at the very bottom of the cummunity, now I'm actually getting 18 + go figure.
Well, it you are driving more gently, as was suggested that you do, you would expect to get better gas mileage. Anyway, it's nearly impossible to accurately compare one day's mileage to the next. You need a long term average.
