Lownslowlsc
My neon ballast stopped working on me this last weekend. I was reading up on glitchs site and it said to cut or insulate the wire mesh coming from the panel that is normally grounded the the inverter. Have any of you done this? I will be replaceing it with a functional oem unit.
There is another blk ground wire that attached to the inverter base, should I leave that one intact? I'm assuming yes.
Lastly, what type of epoxy have you guys used reattach the neon housing mounting bolts/studs? Would some jb weld suffice?
