SleeperMark
I swapped out my ring and pinion yesterday along with all new bearings. When I checked the backlash it seemed to read right at .010. My compound pattern was faint bit it looked like outer tip on drive side and inner tip on coast side. Now here comes the problem.... First problem is I used a 3/4in impact on the pinion nut and Im not sure it is tight enough because when I shift into reverse I hear a clunk. Second bigger problem, (you guessed it) They moan.
The worst is at 18mph and its off and on until I get above 50mph. Checked the oil today after 60 miles and it is glittery and very thin, (almost like water). I used Oreilly's MasterPro brand (80-90) just to get the break in out of the way and then I was going to put in a synthetic. I am at a loss now tho. Brand new gears and I really dont want to trash them. How much does that crush sleeve take? Should my yoke have ANY play? (right now i would say it can move 2 or 3mm in and out). Would a loose pinion even cause moaning? And would it even be worth my time and money to have it professionally set up before I kill them, or are they already done? Thanks for any input. I will listen to you all next time when you say have a pro do it.
