mossbergman
I've been having all kinds of fun just datalogging. I need to make an appointment with wichita dyno, wait for cool air, and go for low 14s. Im getting closer, its exciting!!!
Do you think you'll get 280 in the heat? I'm shifting manually when I go all out and try for just below the limiter, which is at 6300ish rpm. I call for the shift at 5500-5600, and by the time the damn thing gets around to it, it happens at around the limiter. If I miss though, it makes a very disturbing snick snick noise along with the sound of it bouncing off the limiter. So I don't do it much![]()
How? It has 3 tunes on it, but I think they are for a 05-10 auto stang. It will let me mess with shift rpm and pressure for the 4-5 shift, which we obviously don't have. I'd hate to put a 3v 5r55s tune on it and fry something:shifty:
and all this is being done with an unchanged shortblock? the only real mods your running are the cobra intakes? aside from tghe norm being full exhaust .
Have you logged KNOCK RETARD? Do you have any at WOT?
hey what is your exhaust? i watched your last lsc wot vid and your car sounds eargasmic
My car should stay around 5K rpm on the fall back into the next gear on both shifts.
This is my shift points blowing through the old converter...![]()
Dude. You gotta be kidding me. Is that with the 5.3 ??
Yes, that was from one of the datalogs with the new motor. Proof positive the old converter wasn't up to the task since the rpms didn't match the trap speed.
What do you mean by that exactly?
