Wtf happened to my car
Or if you have an overhead jib crane, you can run a strap thru the windows,
or let all the air out of the tires and fill them back up with helium
I just drive my car on top the jack and jack it up by the tire, or else i just dig under it to do any work to the underbody
i was going to put a clip, or a pic up of andy samberg, on the movie hot rod, when he's in the garage trying to impress the girl by beating the engine with a mini sledge
do it!
edit: wtf is with this site putting things that were typed in all capitals, into lowercase? Kind of killed it.....
my favorite is jacking directly under the door handle too...usually after doing this, I have to replace the door handle, though, wish they had designed these better.
Never jack any car by the oil pan unless u want a new problem . If your doing something you don't have to remove tires for I highly recommend ramps.
couldn't find it
FAIL
Well sometimes I like to put ramps on top of the jack, drive the car onto the ramp, and then jack up the ramps. I'll then put three jack stands under each ramp. For the rear of the car I just shrug the back end up and put a stick under it to keep it up.
i usually just adjust the air ride sensors so it would keep putting air into the air suspension until it lifts 3 feet up in the air
