worst 2 days of my life
Not sure if the LS is like this or not but a lot of newer cars use "Torque to yield" bolts. Once they have been torqued, they are stretched and not to be re-used. Kinda sucks, I had the heads off my '65 Mustang a dozen times and never had to get new bolts. Technology & progress!
Yes, the LS uses torque to yield bolts for the heads.
I see a bunch of BS on that estimate too. They charged to clean spark plugs? Then charged for a new set of spark plugs? 700 for a head gasket set? F*ck you. I've never checked prices for that, but that's a fark ton of money for a gasket set.
And a $15 discount on $1100 in parts? I'd punch them in the d*ck for such a statement.
Get all your parts from Tasca or Max and only pay the labor. Or cut the bill in half and just install a different engine.
Is there a more reputable shop in your area? Are you SURE it's head gaskets? I honestly have never heard of one fail on an LS. Then again, if you have been overheating, and overheating for an extended period, it could warp the head.
My local trusted shop charges 62.50 shop labor. Dunno where you are at, but $90/hr sounds like dealership labor.
I agree! I would look at your de-gas bottle and make sure it wasn't replaced.
If it was they conned you into a bunk repair bill. De-gas bottles are a common issue with this car that causes the same symptoms. Cheap fix, even cheaper and easy DIY.
so true
head gaskets? something is not right here. Check on the cost of head gaskets. With fail safe mode, can't believe you need head gaskets. good luck
Just think how many people do this type of thing and have no forum to consult for advice. They just cut a check and continue like everyone in the world is an honest person that is doing the good for the people.
You are lucky you have this forum as a resource. Paythem for the labor hours thus far and tow it home and replace all of the plastic cooling pieces and change oil, coils, plugs. Of course ordering your own parts.
Don't let another shop win.
Yeah almost $900 for head gaskets, wow. I like the plugs being almost $15 each. I just got done doing mine with Champion Platinums, after rebate... $0.00 total.
Well, I guess this is what happens with dealers and limited production engines like the V8. Hey wait a minute. Just did some complex figuring(Engineer background yah know), and it looks like you have a V6(ie the plugs work out to 6). Isn't the six banger pretty much a plain vanilla Ford V6? If that is true, then you are really getting a "job".
Jim Henderson
Whoa that makes it even worse.
Nothing special about the six.
2001 LINCOLN LS 3.9L 242cid V8 FI (A) DOHC
Coolant Recovery Tank
DORMAN Part # 603207 Coolant Reservoir; No Low Fluid Sensor
Includes Reservoir Cap D
$62.79 $62.79 Remove Part
Radiator Cap
MOTORCRAFT Part # RS527 {#1W138101AA, F6DZ8100A, RS103}
lbs: 16 B
$5.91 $5.91 Remove Part
Thermostat
MOTORCRAFT Part # RT1154 {#XW4Z8575CA} Therm 190
w/ 54mm; By Pass B
$15.15 $15.15 Remove Part
Cylinder Head Bolt
FEL-PRO Part # ES72262 Head Bolt Set
Head bolts w/Washers; Replacement recommended B
$34.79 $34.79 Remove Part
Cylinder Head Gasket
FEL-PRO Part # 26364PT Head Gasket PermaTorqueMLS®
Head bolts not incl.; Head bolt replacement recommended; Right B
$35.79 $35.79 Remove Part
FEL-PRO Part # 26361PT Head Gasket PermaTorqueMLS®
Head bolts not incl.; Head bolt replacement recommended; Left B
Intake Manifold Gasket
FEL-PRO Part # MS96936 Intake Manifold Gasket Set
Lower Set D
$12.18 $12.18 Remove Part
Timing Cover Seal
VICTOR REINZ Part # 67778 C
$9.79 $9.79 Remove Part
Valve Cover Gasket
FEL-PRO Part # VS50724R Includes Left & Right Side PermaDry®
w/Grommets & Spark plug tube seals; molded rubber gskts. incl. D
$39.79 $39.79 Remove Part
Spark Plug
AUTOLITE Part # 3924 Resistor (Rebate/Promotion Available! See Promotions & Rebates Page for Details.)
GAP .044
+ Sold in packs of 4; Price reflects cost of each individual item, not the pack D
$1.01 $8.08 Remove Part
COP Coil Boot
UNITED IGNITION WIRE Part # 972S
Boot and Spring Kit
+ Sold in packs of 4; Price reflects cost of each individual item, not the pack A
$2.92 $23.36 Remove Part
Thermostat Housing / Water Outlet
MOTORCRAFT Part # RH146 {#96JV8594BD, WC95648X, XW4Z8592BD}
Thermostat Housing B
$14.92 $14.92 Remove Part
Thermostat Seal
FEL-PRO Part # 35847 Thermostat Gasket D
$2.26 $2.26 Remove Part
Subtotal $300.60
Discount -$15.03
Country: Postal Code:
Shipping from 4 locations:
Shipping Location B Ground (FedEx or UPS) $11.90
Shipping Location D Ground (FedEx or UPS) $12.44
Shipping Location A Ground (FedEx or UPS) $11.22
Shipping Location C Ground (FedEx or UPS) $15.85
Total $336.98 Rockauto.com
This is including the 5% discount code that anyone can get.
Add oil, oil filter and antifreeze from anywhere- 50 bucks.
2975.39 - 386.98=2588.41
2588.41/90hr shop rate = 28.76 hours
If I remember correctly this is a 12 hour job.
12x90 = 1080
1080+386.98=1466.98
1466.98+6% tax=1560 TOTAL including everything
I have made it quite obvious they are ripping you off. I even added some parts in the cooling system that I know ill fail in the near future and I included some engine gaskets that they did not. It is not understood what they mean by spark plug boot. Maybe they are melted. I added 8 of those also. This is for the V8. See below for the V6
the funny thing is i read these fourms way before i had the money together for the car and i perpared my self
i paid 1500 for a full 5 years warrenty on the car that covers everything from a little scratch to the transmisson and engine so i dont have to worry about that and another great thing i have full coverage and with my warrenty i dont need one penny for the deductable:cool: :cool: :cool:
So you have a warranty??
why are you paying for this??
2001 LINCOLN LS 3.0L 182cid V6 FI (S) DOHC
Includes Reservoir Cap E
Radiator Cap
lbs: 16 B
Thermostat
MOTORCRAFT Part # RT1141 {#XW4E8575AA, XW4Z8575AA} Therm 190 B
$14.22 $14.22 Remove Part
Thermostat Housing Gasket
FEL-PRO Part # 35742 E
$0.80 $0.80 Remove Part
Water Outlet Gasket
MOTORCRAFT Part # RG571 {#F1VY8255A} B
$4.70 $4.70 Remove Part
Thermostat Seal
FEL-PRO Part # 35489 E
$3.93 $3.93 Remove Part
Cylinder Head Bolt
FEL-PRO Part # ES72208 Set
Head bolts w/Washers; Replacement recommended DE
$32.79 $65.58 Remove Part
FEL-PRO Part # 26248PT PermaTorqueMLS®
Head bolts not incl.; Head bolt replacement recommended; Left E
$49.99 $49.99 Remove Part
FEL-PRO Part # 26249PT PermaTorqueMLS®
Head bolts not incl.; Head bolt replacement recommended; Right E
FEL-PRO Part # MS96475 Set
Lower Set D
$25.79 $25.79 Remove Part
Timing Cover Gasket Set
FEL-PRO Part # TCS46054 Crankshaft Front Seal Set
Must be used w/OS 30697R D
$23.79 $23.79 Remove Part
Timing Cover Seal
VICTOR REINZ Part # 48322 {#C2S48116, F3AE6700AC, F5AZ6700A} C
$7.71 $7.71 Remove Part
Valve Cover Gasket
FEL-PRO Part # VS50610R PermaDry®
w/Grommets & Spark plug tube seals; molded rubber gskts. incl. E
$44.79 $44.79 Remove Part
COP Coil Boot
UNITED IGNITION WIRE Part # 971S
Boot and Spring Kit
+ Sold in packs of 3; Price reflects cost of each individual item, not the pack A
$2.81 $16.86 Remove Part
Spark Plug
AUTOLITE Part # 104 {#XP104} Xtreme Performance (Rebate/Promotion Available! See Promotions & Rebates Page for Details.)
GAP .054
+ Sold in packs of 4; Price reflects cost of each individual item, not the pack E
$1.08 $8.64 Remove Part
Subtotal $385.49
Discount -$19.27
Shipping from 5 locations:
Shipping Location E Ground (FedEx or UPS) $14.27
Shipping Location B Priority Mail $9.63
Shipping Location A Priority Mail $6.13
Shipping Location D Ground (FedEx or UPS) $15.87
Total $427.97 Rockauto.com
Includes 5% discount that anybody can get.
Add 50 for oil, oil filter, and antifreeze. 477.97
2975.39 - 477.97= 2497.42
2497.42/90hr shop rate= 27.75 hours
I do not know about the time required to this job but I am sure it is not far off of the V8 time of 8 12 hours.
90x12=1080
1080+477.97= 1557.97
1557.97+6% tax= 1651.45 TOTAL including everything.
I included parts that are going to fail soon if they have not already failed in the cooling system. I also included all coil boots. I think you are getting ripped off.
+1 Most likely degas tank. Mine used to regularly dump its load everywhere. And if thats new, then its probably air in the system or some cheap plastic. Tow to a Ford dealer if its under warranty, fix yourself if its not. I have never seen a blown head gasket in all the complaints here. Not impossible, but very hard to believe! I though my $8 NGK irridiums were insane. I would slander this garage's name all over the place... total crap! And that insulting discount... is that even enough to buy astro glide these days? :( Don't let them F you!
Dude they are trying to get by on you. I replaced my whole timing assembly for less that and that is a lot more parts then you had. Included in that total was a thermostat housing, serpentine belt, and coolant crossover pipe. The Ford head gasket was $60 so I dont know where they got you that price. I agree with the rest of everyone and get your car back from them. Damn this just pains me to hear.
Jesus, you're getting f'd...Anything under 1700 would be acceptable. They will make some money on parts no matter what, but thats outragous.
Do your homework, show them what it should be ($$) and agree on a price if it is indeed the head gasket. If it's not take it somewhere else.
P.s. I would have surprised them with a visit, assuming you called to let them know ur stopping by. They've allready showed that there out to f you. For all you know they could've contaminated the oil/coolant before you're arrival...02
P.s. I would have surprised them with a visit. They've allready showed that there out to f you. For all you know they could've contaminated the oil/coolant before you're arrival...02
Good point. I was just watching something about garages that do this. There are way more out there than you could believe and its a shame.They could have made sure all this is f&^%ked up so you have no choice but to fix it all.
I'm surprised the mechanic didn't do a standard headgasket check with the little doohickey thingamajig tool that looks for exhaust gasses in the coolant.
And 14 bucks for spark plugs?
Man, you ought to see what they charge for plugs at the Stealership for my 05 F-150! :eek: They want $21 a piece! I bought a set of E3's at Advanced and handed em to the service rep.
Sorry to hear. If they haven't started working on it, I would get the car back, get your own parts and do it yourself, or find someone to help you.Should've checked here first before letting them do any work. Use the forum man, it will save you a lot of money.
Alax aint shi!!in ya. This forum has saved me literally thousands.
well guys i took your advice got the car towed out of there and into a friend ofa friends shop car should be ready by thurs and im paying 1800 for parts and labor better than 3000 i guess lol
Good choice! That is WAY better.
