Wierd Beeping Noise
Went to my local Ford stealership and they searched their bulb rack and found one. So all I need to do now is replace the old one when my wife gets home from work. I hope that does the trick. If not, I don't know what I'm gonna do with that crazy beeping. I feel like a moron for taking the dam thing out to begin with.
Let us know, then count the airbag light flashes. There should be one set, a pause, then another set.
Okay. Got the new bulb in and the beeping stopped. And it blinked "3" "3", so code "33". Anybody know what that is?
Edit: Found it. Code 33 is high resistance or open circuit in the passenger side air bag. Anyone had this problem? Where is the pass. side air bag sensor?
Again, thanks for all the help!
Passenger side airbag circuit high resistance
or open.
This is what I needed! Thanks Guys! I got a Code 45 which translates too...
"45 LH radiator primary crash sensors not mounted to vehicle properly"
So my question is do I have to ground it better?
I had to rebuild my front end after my crash and it has been doing it since.
Also the air bags did not go off.
