American Air-1
Just wanted to drop a line and explain the reason for the delay of the newly designed Spider Extreme V3. (We hope to have all the preorders in the mail by the end of this week) (1/16/09)
The preordered Spider Extreme V3's were actually built and ready to go the beginning of last week when it hit me.....because of the flow-through design(flowing through the dryer), its probably gonna be allot quieter than the original Spider & Spider Extreme. Although being quiet might be a draw to some people(older generation), it was one of the major draws for the majority. Anyway, after many hours BACK on the drawing board, I came up with the solution. The NEW Spider Extreme V3 was redesigned AGAIN to go both ways! In other words, with the NEW Spider Extreme V3, you have the choice to use it in the flow-through mode that protects the compressor by venting air through the dryer....then through the water seperator and then finally through the solenoid......
-OR-
.....by moving the selection lever to the bypass mode, the air bypasses the dryer completely and the air is vented only through the water seperator and solenoid and will make the loud venting sound just like the old Spider. With the new design, you could run the vehicle in the flow-through mode during the week and "uncap" the system for the weekend!
BTW, for those who order the Spider Extreme V3, you will be sent a FREE Spider Extreme V3 decal to put on your Mark VIII.
-OR-
