Who uses bigger fuel injectors ?
squirell
boca raton
Anyone ever use bigger injectors ?
Looks like I'm in the market for a set and thinking maybe
I should go bigger then the 24 lbs we use now.
Low or high imp. ?
Larger fuel injectors are pretty much worthless unless you need the addition fuel like NOS super or turbo charged, cams ect.........
His car is on the sauce I believe.
Iam running what ever stock 03 cobras are. but got 03 cobra heads and 01 intake and cams xe262AH
I am running a 125 shot,
Maybe stepping up to 150
Hey what kind of kit wet or dry. R U having problems with a lean mix. I run gas a 125 dry kit. I am still running stock injectors. Any idea what the duty % is on the stock ones while sprayin. BTW what psi fuel do you ran at idle. 40 psi here
Forget bigger injectors just ran a wet nitrous setup. It hits a lot harder...
The stocker 03/04 Cobra injectors are the 39 lb/hr EV6/EV6 USCAR injectors.
The 04 Mach 1 and Aviator injectors are 24lb/hr.... right? The Cobra being bigger because they are factory blown?
I love my wet kit! 150 is unreal! Doesn't last long though and n20 isn't cheap
If you go through enough, you may want to look into a fill station, I bought one from ebay a while back, and opened an acct at my local gas supplier and I was paying $46 for a 150lb cylinder.
I bought the fill station used for $150, so it was a worthwhile investment.
At the time I was spraying an intercooler setup, on an 86 cressida with a 2JZ I regret getting rid of it everyday, it was such a blast to drive.
