01LincolnLSV8
i'm looking for my PCM code for my car so i can give it to a someone to make some tunes for me with an Xcal. Where would i find it??
Thanks,
Josh
Thanks,
Josh
Quik LS said:it is a sticker on the end of the PCM.
the PCM is up under the dash behind the glove box - and you can usually see the code without removing the glove box (which is a PITA)
Remove the passenger footwell plastic cover - held in with plastic push-pins.
Lay on the floormats head under the dash and with a flash light you should be able to see it.
Torrie from FastPartsNetwork can usually pull your PCM code using your VIN - you can just e-mail him.
