I guess when I wrote new member you took for granted new to cars.
NYC LS8 as I am sure you already know displacement does not equal faster,sometimes less is more. I would rather look into purchasing a package unit due to the cost involved. I don't want to spend my time re-inventing the wheel if some one has already suffered the R&D costs.
Don't knock the smaller engines. I have seen quite a few 800+ horsepower V6's and even a few I4's. Not saying the LS 3.0 is one of them but sometimes respect is due to those smaller engines.
I am just looking for a little bit more... As i said its a daily driver, I have an 88 GT 5.0 to do stupid things to. I looked at different power adders and a turbo, most likely remote mounted would be the cleanest application. The car will probably never see a Dyno. Definitely not any sort of track...I think
I do appreciate the links given, as for the V8 vs V6 war I have owned some big V8s and some small 4 cylinders and some 6cylinders. I rate the car buy driving it not buy measuring displacement.
Weight to power ratio.. My bike has a 1 liter motor only puts out 100hp its weighs 600lbs with me on it. Its goes pretty good
What kind of stock I4's have the internals to withstand 800+ hp? Just curious.![]()
Pump Gas? NOT!
I'm sure there are some 1400 hp nitromethane 4 bangers running around.
Once again the answer here is obvious. Did you really believe that I was mentioning a pump gas vehicle? However you do not need to run friggin nitromethane to get some VERY solid numbers from the smaller engines when they are built for it.
And yes I would like to find a Twin turbo set up... go big or get the *%$#@ out of my way.
You guys should really try an attempt at understanding the context of what I was saying rather than jumping to ridiculous conclusions.
