99 Interceptor
I picked up a set of 18 Jag wheels from another member, bolt pattern and hub size are the same off set is pretty close but back spacing is a problem, they fit fine on the rear but with a 245/45/18 mounted the tire is up against the spindle and upper control arm.
I'd need about a 1/2 inch spacer for the front for clearance, so the question is did anyone with after market wheels have to use a spacer on the front? and did you have any problems?
I'm trying to decide if I want to go the spacer, longer stud route or just bag this idea and go with a different wheel.
