Right now I am not running any cause I need another xcal. And my trans tune is altered in speed and load and RPM. You need the full software package to do that. I am adding as much as 45psi in the upper load/speed/rpms for the 1-2 and about 20psi in the 2-3 shifts. Also took some pressure away inder very light loads. Its a quite complexe setup and took several months to get perfect. That car shifts so smooth you dont even feel it when puttering around but at WOT it will break the tires loose going into second and bark 3rd pretty hard.yea I agree and that's what I'm seeing now with my xcal....at only 5% it's still smooth as can be at low rpms I want to try bumping it up quite a bit, but I'm reading now that increasing the line pressure will overheat the trans.....so a trans cooler is needed now.
Have either of you bought a trans cooler yet? Laser, how much increase in line pressure are you running?
