What is Fuel Computer Data Error??????
Lincoln LS
  1. DUVALINCOLN
    DUVALINCOLN Active LVC Member
    125
    Nov 30, 2008
    Tally
    LVC, I walked out to my 2004 LIncoln LS this morning and when I turned on the engine I saw this code which wasn't there last night. I tried to clear it but didn't work. Car seems fine and i know I have fuel. What is this and how do I fix it?????
  2. gcwimmer
    gcwimmer Dedicated LVC Member
    2,647
    Nov 17, 2006
    Reno, NV
    Disconnect the negative battery cable for about 1/2 hour.
  3. DUVALINCOLN
    125
    Nov 30, 2008
    Tally
    I disconnect the battery for about 45 minutes and upon re-connecting battery, fuel Computer Data Error returned and gas gauge is still non-reactive.
  4. 1LoudLS
    1LoudLS Dedicated LVC Member
    9,904
    353
    Mar 31, 2008
    Ann Arbor
    sounds like there is an error in the data the the computer uses to tell you how much fuel you have. you might have a problem with the fuel level sensor in the tank
  5. joegr
    joegr Dedicated LVC Member
    19,946
    1,507
    Dec 10, 2005
    Gulfport
    It's not "the" fuel level sender, there are two of them.
  6. 1LoudLS
    9,904
    353
    Mar 31, 2008
    Ann Arbor
    darn, that would be too easy
  7. joegr
    19,946
    1,507
    Dec 10, 2005
    Gulfport
    A Ford specific scan tool will allow you to see the reading from both senders (one in the left side of the tank, and the other in the right side). Looking at the readings, it should be clear which has messed up, if not both. It could, of course, be the wiring or the REM (it reads the senders) at fault instead.
  8. DUVALINCOLN
    125
    Nov 30, 2008
    Tally
    Does that mean I need to consult the dealership? Sounds expensive.
  9. Hawk03
    Hawk03 Dutch User
    1,006
    4
    Apr 17, 2005
    LS
    Do you have a after market remote start/alarm? If you do then check the wire connections.
    I was getting this message too, I checked the wire connections, fixed the bad connection and the message was fixed.
  10. joegr
    19,946
    1,507
    Dec 10, 2005
    Gulfport
    http://www.lincolnvscadillac.com/showthread.php?t=67703
    For the continuation of this story.
  11. Bosshog007
    Bosshog007 Active LVC Member
    64
    Jul 1, 2007
    Memphis
    1loudls said the fuel "sensor" not "sender"
    When I replaced my fuel pump I got that message. In my case it was the fuel level sensor. The wire that leads to sensor came loose and had to be soldered back on.
  12. Bosshog007
    64
    Jul 1, 2007
    Memphis
    Nevermind my post, i read the continuation after I posted. GENIUS!!
  13. 97stscaddy
    97stscaddy Dedicated LVC Member
    2,238
    Apr 7, 2007
    Charlottesville, VA
    Check for blown fuses before you go tearing things apart. There's one in the passenger kick panel fuse panel that does something with the fuel computer. I don't recall exactly which one it was though.
  14. 209jaguar209
    209jaguar209 New LVC Member
    Oct 4, 2010
    LOCKEFORD
    Fuel computer data error
    Hi, i have a 2002 jaguar s-type,, and i have a week trying to figure out what could it be..i changed the battery. I changed the fuel filter. It would start and everything. But when the message would come up it wouldnt start no more. I added fuel additive..lucas. And now it wont start at all! :( did anyone get it fixed??
Share This Page
