ponytail john
Now my car started to sqreech on startup and while running and I mean loud, high pitch sqreeching from the front of the engine. Can't pin point where it's coming from. Took the belt off and spun the pulleys and they seemed all tight, no wobble and sounds. The belt is about 4 months old and for the heck of it I kept the old belt and installed it and the same noises. I hope the hell it isn't the compressor because sometimes it sounds like it's coming from that area and then it sounds like it's coming from the water pump and then the idle arm pulley. The car is getting back at me for some reason, first the blow out plug on the underside of the intake blew out and now this, wow! I guess I'll start with the idle pulleys, then the water pump and then the compressor, the car just turned 70,000 miles and it's a 93. The car isn't over heating and the alternator is maybe a year old and no electrical problems so I'm stumped.
