starfox86
I started off with four brand new tires, jag str wheels with spacers up front, eibach springs and an alignment. Now after about 30,000 miles I am changing wheels. When I took the wheels off I noticed both right front and rear wheels have more thread wear than the lefts. The front right wheel is also really worn on the outter part of the tire. I have no idea what this is from. I have new wheels and tires on now and I am trying to get even wear from the tires. I noticed that when I put the spacers on, I have a shimmy in the steering wheel. I think that one of the spacers must be bent which could have caused the excessive wear on the old front tire. I will be getting an alignment check this week but it should be ok. I am also thinking a loose lower ball joint could be causing this issue. I will check them tomorrow. Idk, im just kinda pissed about the uneven wear.
