Water On Passanger Side Floor...
Dawkins
Toronto
Anyone ever experienced water on the passanger floor...Enough to drowned someone in...Turned on the ac recently due to warm weather...Thing is the car hasent moved in a number of months...Recently also washed the car...Tryed the ac vents don't seem to be leaking took the plastic cover off and no leaking...Any thoughts?...Thanks
-Your Boy North Of The Boarder
I don't know much about these cars. But in the Grand Prix, this is very common. The drain for the ac gets clogged and then backs up and comes out of where the blower motor is. Soaks the passenger floor boards.
When it happend to me, I found where it drains on the firewall and shoved a wire hanger up it to unclogg it. then water poored out and problem was solved. I also added a cabin air filter at that time to prevent happening again (prix didnt come with one from the factory but has the place for it, so i ordered one off of a regal and it fit)
Probably not much help for you but sometimes I like to post just so people know I am here:D
Thanks Bro...Yea when i used to work for Acura that was a common problem...Spider webs would clog the ac drain pipe...Kind of dirt...Thanks bro totally forgot about that
steamin up at all on the windshield? Heater core if it is.
also check the fender well area it is very likley that it is rusted thru. mike 94m5 has a picture of the area on his post about reworking the 95. it will let water into the passenger side. jd
I know this is an old thread but this just happened to me today. Can anyone tell me or show me where to find the drain on the a/c so i can check to see if it is clogged. girlfriend got in the car today and asked "why is the floor wet!". any help would be appreciated guys.
