NoLimit95
So what's the deal on the F3 W3Z2's? I thought as long as you had a Z2 you were golden. What's the difference between a F3 Z2 and just your regular W3Z3?
W3Z3 WOT spark
6000.000 27.0
5000.000 24.0
3500.000 23.0
3150.000 19.0
3050.000 14.0
2500.000 12.0
2000.000 12.0
W3Z2 WOT Spark
6000.000 32.8
5000.000 29.0
3500.000 26.5
3150.000 22.3
3050.000 17.0
2500.000 15.0
2000.000 13.0
W3Z3 Rev Limit 6450
W3Z2 Rev limit 6850
W3Z3 1-2 shift 5600
W3Z2 1-2 shift 5600
W3Z2 speed limit (driveshaft revs) 16372= no speed limiter
W3Z3 speed limit (driveshaft revs) 5400 = max speed limited!
Shift pressure on the W3Z2 PCM is about 15 PSI higher as well, for a more solid, quick shift.
Once the 93 has been chipped, none of the above applies anymore. It will be as equal as the next PCM that is chipped, depending on programming, etc...
