Cheez_94
Before anyone flames me, yes I did a search. The shake feels like it is from the drivers side primarily
The strut rod bushings have been changed on both ends.
The ball joints appear to be fine (C clamp/mongo channel lock test)
The lower control arm bushings appear to be fine
The upper bushings have very, very slight movement
The outer tie rod end on the drivers side is a little loose but I would think that would be enough to cause shaking this violent.
The rotors are within tollerance for run-out
Thanks for any help with this in advance
