anyone in a lincoln back to the mark vii are all vlcm.
1996 Lincoln Mark VIII "Variable load control module" issues
question: where is the constant control relay module in my 95 mark viii?
Eric :
Hi. Your Mark VIII does not have a CCRM. If you have a another question related to a problem you are having, please ask. Thanks, Eric
Customer : What is controlling a/c and fans and location
Eric :
Ok. You are correct. The variable load control module controls the cooling fan operation.
Eric :
CLICK HERE for wiring diagram of VLCM
Eric :
CLICK HERE for VLCM vehicle location
Read more: Relay..it the same thing as variable load control module - JustAnswer
http://www.justanswer.com/ford-linc...riable-load-control-module.html#ixzz1wSgJtF5k
anybody know where i can get a variable load control module for my '96 mark VIII? very hard to find part, so i appreciate any suggestions. thanks in advance...
#2
01-09-2008, 07:00 PM
jamies98lsc
Senior Associate
96 is 96 only and very hard to find. my buddy Ed has one he is selling currently. he is not a member here but another board, tell him Jamie sent you. here is his email. tell him i expect 10% commission!
elezon@earthlink.net
#3
01-10-2008, 12:54 AM
jamies98lsc
Senior Associate
i guess Ed has it on ebay, here is a link if you still need it.
http://cgi.ebay.com/ebaymotors/MARK-...spagenameZWDVW
June 25th, 2008, 01:23 PM #10
unity
Full Member
Great. One more thing to add to my "96 is the ONLY year with:" list.
__________________
1991 Mercedes 560 SEL (Its like a Mark, but better!
June 25th, 2008, 05:19 PM #11
Moes8
Full Member
Quote:
atleast it makes it
apparently the 96 is the only year thats different.
and its not even called that its a ccrm
The EEC system has two major divisions: hardware and software. The hardware includes the PCM, Constant Control Relay Module (CCRM) or Variable Load Control Module (VLCM), sensors, switches, actuators, solenoids, and interconnecting terminals. The software in the PCM provides the strategy control for outputs (engine hardware) based on the values of the inputs to the PCM.
its a common mistake since its been misrepresented for so long. but the correct terminology is......VLCM.
a simple google search will bring you to other forums, ask a lincoln mechanic,i even called a dealer, although part is discontinued still calls it VLCM.
even this ebay post is a 93...
http://www.ebay.com/itm/93-LINCOLN-...Parts_Accessories&hash=item43b04a6d2a&vxp=mtr
:blah::blah:
