ok i had installed this system in my car. well it consist of:
2 12 w7
2 1000/1
2 sets of 5x7 xr
300/4
eclipse avn6600
power acoustic 8 inch headrest
2 yellow top optimas
1 batcap
1 battery isolator
200 amp alternator
ok when i got this system all installed, the guys had killed my battery while they were installing it. so then they had turned the car on and i guess it was to dead so it put a lot of strain on the alt so it blew the regulator on the alt. so i had gotten the alt regulator fixed they put a new one in. so im driving and now i get a battery and a check charging system error code. and then this morning i had started my car up with my remote start and then i went out to my car and it was running so i thought everything was ok. so i put the key in and then turned it to ignition or acc whatever then i mashed the brake and the car died. so i try to start it again and then it wouldnt start. so i called the place up to see did they install everything as far as ground and power wire they said they did but they will check again. so i towed it to the alt place and he said something was draining my system while its off. so i said how when i was driving and i got the battery error and then he said maybe when they blew it it also blew the diode or something of that matter can someone help me please. i dont know if its the cables in the back or the alternator.
2 12 w7
2 1000/1
2 sets of 5x7 xr
300/4
eclipse avn6600
1 batcap
1 battery isolator
200 amp alternator
