Unbelievably tired of weird issues..
Lincoln LS
  1. MMAFIGHTER121
    MMAFIGHTER121 Dedicated LVC Member
    760
    Jan 16, 2008
    Syracuse
    possible solution to check next:
    since I'm also having weird troubles with the Cruise engaging, it lights up then back off almost immediately as if I hit the brakes.. I'm wondering if the Lincoln has a switch in the brake pedal that interrupts power to the TCC solenoid when they're applied, like a lot of cars do, and if that has gone awry, or a brake sensor of some sort is the issue.
  2. joegr
    joegr Dedicated LVC Member
    19,366
    1,392
    Dec 10, 2005
    Gulfport
    If gen I is like gen II, then -
    The brake light switch (under the dash, at the pedal) is used to
    Disengage the cruise control.
    Light up the brake lights.
    An input to the PCM that it may use to disengage the torque converter (other inputs may have to be in certain ranges too).
    Disengage the shifter lock (if in park).
    There should also be a hydraulic brake pressure switch (at the master cylinder) that is used to interrupt power to the cruise control servo. (This is a failsafe on the cruise control.) I don't know if it is monitored for anything else. On gen II, it is an input to the PCM since there is no cruise servo to de-power.
  3. MMAFIGHTER121
    760
    Jan 16, 2008
    Syracuse
    Hmmm.. wishing I had more concrete details on Gen I because the way it sounds, if my brake lights light up, then this switch is not the issue, despite sounding pretty spot on.
  4. joegr
    19,366
    1,392
    Dec 10, 2005
    Gulfport
    Do you know for certain that they aren't lighting up when they aren't supposed to, because that would be the problem instead of an issue with them not lighting when they should.
    Incidentally, Ford had problems in the early 2000's with that hydraulic pressure switch and fires. My 2001 Ranger has that switch and was recall for it. (The result of the recall was that they plugged an extra harness into it that has an in-line fuse.)
  5. MMAFIGHTER121
    760
    Jan 16, 2008
    Syracuse
    Ah. I see what you're getting at.. it would be actuating at random, not not actuating when I want it to. Hm. That'll be trickier to test.
  6. MMAFIGHTER121
    760
    Jan 16, 2008
    Syracuse
    Ok - so the last few days I've taken it out for a spin and done a TON of top gear cruising and I haven't had any lockup/disengage issues unless I try to turn on the cruise control...
  7. joegr
    19,366
    1,392
    Dec 10, 2005
    Gulfport
    Maybe you should take a look at the cruise control module/servo.
  8. MMAFIGHTER121
    760
    Jan 16, 2008
    Syracuse
    Ehhh.. came back today after a few days of no issues in its full erratic glory. Think I have to take it somewhere with one of those serious scanners to read when its locking/unlocking.
Share This Page
