Transmission slip
Lincoln Mark VIII
  1. Poem 58
    Poem 58 LVC Member
    17
    Feb 10, 2019
    Nixa mo
    Hi guys ,
    I have noticed on my 1994 mark viii when iam cruising around 60 mph the trans downshifts for no apparent reason. Also a few time slipped in a lower speed, but only occasionally, any ideas?
  2. xtriggerman
    xtriggerman Active LVC Member
    111
    29
    Jan 7, 2019
    TN
    Is it still doing it after a fluid & filter change?
  3. Poem 58
    Poem 58 LVC Member
    17
    Feb 10, 2019
    Nixa mo
    Yes
  4. xtriggerman
    111
    29
    Jan 7, 2019
    TN
    Could be a broken valve spring. This would make the trans slip into a different gear at random. Definitely needs a trans guy to pull the valve body and check the valve springs/cylinders.
  5. 04_Sport_LS
    04_Sport_LS Dedicated LVC Member
    3,425
    391
    Jun 12, 2012
    Somewhere around Lake Erie
    I would make sure your shifter cable is not worn/stretched... and is adjuted properly.
    Also... probably wouldn't hurt to change out your MLPS... also known as neutral safety switch... reverse light switch... gear selector switch... etc.
  6. NickPims
    NickPims Active LVC Member
    163
    4
    Jun 4, 2010
    Russia
    Last time I saw such "range hunting" it transmission - it was a speed sensor. No other simptoms - correct speed at instrument cluster, no problems in any of the modules using speed sensor data - just speed hunting in special conditions (2-3-2-3-2-3 or 3-4-3-4-3-4 several times in cosistent driving conditions).
  7. Poem 58
    Poem 58 LVC Member
    17
    Feb 10, 2019
    Nixa mo
    I took the car to a transmission shop and they said the yoke seal is leaking, so I'm going to have this fixed and go from there. The car only has 42000 miles thanks guys for your input
  8. joegr
    joegr Dedicated LVC Member
    20,155
    1,556
    Dec 10, 2005
    Gulfport
    Is it really leaking (fluid level going low, fluid on the ground), or is it just seeping a little (just damp around it)?
    Unless the fluid level is low, this will have nothing to do with your problems.
    This "shop" wasn't AAMCO or another chain was it? Find a good local independent shop, the one that all the other repair shops farm their transmission work out to.
  9. Poem 58
    Poem 58 LVC Member
    17
    Feb 10, 2019
    Nixa mo
    It is pretty reputable shop he said add fluid once a week probably a fairly good leak amoco. Thanks for your advice
  10. Judy Sisak
    Judy Sisak New LVC Member
    4
    Nov 14, 2019
    Florissant Missouri
    Hey guys I just wanted to ask you all about my 2004 Lincoln Ls 6 v transmission problems anyone who has had problem with there I need to ask you some question about it
  11. Poem 58
    Poem 58 LVC Member
    17
    Feb 10, 2019
    Nixa mo
    No Amcco!
    • Like Like x 1
    • Judy Sisak
      4
      Nov 14, 2019
      Florissant Missouri
      No way would I go there!! Bad place!! Thank you
    • joegr
      20,155
      1,556
      Dec 10, 2005
      Gulfport
      There are lots of threads on the LS forum about various transmission problems. My 04 had the solenoid assembly replaced around 60K miles, and the fluid additive before that. It was still working perfectly at 220K miles when I traded it. On my 06 I had to have a complete transmission rebuild (clutches gone) a little before 200K miles. It was never as smooth as the 04, and still isn't (about 216K miles).
      The main problems seem to be:
      Solenoid assembly faults
      Spring failure in the valve body
      Worn out servo bores
      Broken servos
      Worn out clutches
    Share This Page
