DaleGrib
Had my transmission rebuilt on my 2003 Lincoln LS 3.9 V8 and I have barely put 700 miles on it since the rebuild. However, I am noticing jerking at 15, 25, 30, and 55 at random still. Was assured when they did the rebuild it would cover the valve body and solenoid pack being replaced on top of everything else. However, it's looking like they did not do anything to the solenoid pack nor the valve body. Once I can confirm it was not done should I use the Sonnax Rebuilt valve body that uses the upgraded parts and should I also use the Sonnax Solenoid pack that has also been upgraded or should I go with OEM?
They tried to tell me there was a break-in period after the rebuild but I really have my doubts on how it's doing the jerking at the same speeds as before just not as harsh by any means. I will also say that I did replace the solenoid pack with a new OEM one right before the rebuild like one month prior. Just not sure if it needed to be done again being the condition of that fluid. Also, I have had the car back at the shop for it's 500 mile checkup and I told them my concerns of how it was driving and they said nothing was wrong and it all checked out on their tests.
