Transmission fluid
Lincoln LS
  1. joshua
    joshua LVC Member
    21
    Oct 22, 2019
    reading
    Other day I went to go change the oil and made a rookie mistake and ended up draining the transmission fluid. How do I add fresh transmission fluid is it a pump w a adapter to fill because no transmission dipstick?
  2. DaleGrib
    DaleGrib Dedicated LVC Member
    737
    79
    May 14, 2018
    North Carolina
    The way I have found easy to fill it is to use a garden sprayer. Just to cut the sprayer part off so you have a hose that will go into the fill hole and then you can pump it back in much faster.
    • Like Like x 1
    • AmsterDutch
      AmsterDutch Dedicated LVC Member
      1,934
      323
      Jul 9, 2017
      Midwest
      It's $4.99 on Amazon and fits any quart size bottle
      • Like Like x 2
      • joshua
        joshua LVC Member
        21
        Oct 22, 2019
        reading
        I don't need adapter
      • AmsterDutch
        1,934
        323
        Jul 9, 2017
        Midwest
        No just put the hose into the fill hole and pump the fluid into the Pan...if you don't feel comfortable enough to do it a shop will do for a small fee ...I'm sure any good indy shop would do it really cheap
      • 04_Sport_LS
        04_Sport_LS Dedicated LVC Member
        3,413
        389
        Jun 12, 2012
        Somewhere around Lake Erie
        Josh,
        I think the fill hole Dutch is talking about... is at the back of the transmission... not the pan.
      • AmsterDutch
        1,934
        323
        Jul 9, 2017
        Midwest
        Yes it's at the back of the transmission ...I guess I will be more specific next time and say it will fill the pan
      • 04_Sport_LS
        3,413
        389
        Jun 12, 2012
        It's all good.
        In the mean time you need to step over to your rear toe link thread mister.
      • Kerrigan
        Kerrigan Active LVC Member
        69
        Dec 31, 2011
        Portland
        Don't make the mistake I did; took our '97 to a "we're good" tranny shop which only dropped the pan and then filled it with "Universal fluid", which was TOTALLY wrong!! Took it to another shop recommended by a Mark VIII owner and they did it right. Drained and flushed it all, converter, etc. Filled it with the correct Mercon fluid. The difference between the "wrong" and the "right" was noticable as soon as I drove it home. Smoother shifting, more positive engagement .. didn't "slide into gear" .... Lesson learned: DO IT RIGHT THE FIRST TIME!!! Shop says it's good for two years normal city driving before I should do it again. And the cost was reasonable. Don't take it to a dealer .. ever.
      • joegr
        joegr Dedicated LVC Member
        20,140
        1,548
        Dec 10, 2005
        Gulfport
        Your 97 what? You don't have a 97 Lincoln LS or Jaguar S-type...
        • Like Like x 1
        • 04_Sport_LS
          3,413
          389
          Jun 12, 2012
          Probably my fault Joe. I got bored and crossed over to another part of this forum.
        • AmsterDutch
          1,934
          323
          Jul 9, 2017
          Midwest
          No good deed goes unpunished 04' lol
        • 04_Sport_LS
          3,413
          389
          Jun 12, 2012
          Yeah well.... evidently what they say about idle hands, (and minds)... is true.
        • Kerrigan
          69
          Dec 31, 2011
          Portland
          Lincoln Mark VIII, .. 1997 Base model ...sorry didn't include that data ...
        • joegr
          20,140
          1,548
          Dec 10, 2005
          Gulfport
          Okay. I never had one of those, but they seemed like a pretty good car to me. Just keep in mind that your experiences with that car may not translate to experiences with the LS, as it is a very different beast.
          • Like Like x 1
          • Agree Agree x 1
          Share This Page
