So my friend and I did a transmission fluid change on his Kia Sephia today, and it went pretty smoothly by looking at some videos on youtube. We took off the pan, changed the filter and put in new trans. fluid. Then we took off the hose that goes to the radiator from the transmission. Started the car, took out 1 old quart and then put in 1 new quart. Rinse and repeat till we saw new fluid from the hose.
Well that was easy because there were tons of videos on youtube. I read the tech article posted here and it seemed HARD(a month ago). After we did his car, I read it again now and it seems doable but I have some questions.
1. Where is the crankshaft pulley?? (pictures would be better
2. I have a torque wrench, how tight does the bolt for the torque converter has to be? Also for the pan bolts too?
3. The filter in the tech article says he got a FRAM filter, but aren't they not good?
Which filter would you guys use?
4. My brother has a 93 Mark VIII and I don't think he has the new style pan, where should I get that from?
I will probably make a video and post it on youtube because TBH, the tech article is good for people who actually can work on cars. Everything that I know is by reading the posts here and I am only doing this on the Mark because I just did my friends.....lol.
