Ticking Sound on Freezing Cold Startup
WhoBeDaPlaya
Dallas
Only noticed this today as temp only dropped to 15F for the first time since I got the 06LS. About 5-7 ticks on startup that go away after the RPMs drop down. Anything I should be worried about? Car has been running perfectly fine thus far.
As always, many TIA :cool:
I got ticks this AM also, I was thinking about using a thinner oil maybe?
yeah, I use valvoline synthetic 10w30. It was 22 degrees at start-up this Am. I'm just about due for a change, so I'll probably switch to 5w30. It doesn't really get too much colder here all winter...we may have a week of single digits, but 10-25 usually does it for us.
Most likely its your belt tensioner. I had mine replaced and it is fine now.
Look Below
08/18/08
3.9L ACCESSORY DRIVE BELT SNAP NOISE IN
FREEZING TEMPERATURES
FORD:
2002-2005 Thunderbird
LINCOLN:
2000-2006 Lincoln LS
ISSUE
Some 2000-2006 Lincoln LS and 2002-2005 Ford Thunderbird vehicles equipped with a 3.9L V8 engine may have an accessory drive belt snapping noise for approximately 10 seconds when ambient temperatures are below freezing. A new idler pulley is available to repair this condition.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Install a redesigned idler pulley.
Look Below
08/18/08
FORD:
LINCOLN:
ISSUE
ACTION
SERVICE PROCEDURE
Is this a recall or something?
good god guys.........IT was COLD.
Engines do that type of thing when freezing. You should hear my 180,000 mile 4.6L when cold.
its not a recall, there is nothing wrong with the belt tensioner. it just makes a ticking noise. Mine would be 3-4 snaps. wait a few seconds, and then 1-2 more and it would stop. When i first bought my car, i thought there was somthing wrong when i parked it outside overnight. It is not a recall because it does nothing but tick. half of the U.S. dosen't get cold enough to ever trigger it. Good luck with yours.
