Thoughts on constructing a Lowering switch
More thoughts...
The AS module cannot be fed more than 5volts, I think it would burn it up if you applied too much voltage... However, you can drop the voltage as much as you want. Maybe on a 5 position switch, 1 would be slammed, 2 would be midway between slammed and stock. -- Those positions would have to have voltage added to drop the car. Position 3 would be nothing, it would be stock ride height, and normal operation of the AS. Position 4 and 5 would not have voltage added, rather they would be dropped across a resistor. Less resistance for 4, and the most for 5. That would make 4 a midway between stock and 4x4 and 5 would be as high as the system can go, maybe not 5 volts, but like 4. Over stretching the bags could blow them out.
I have an asham8, I've been considering fixing the factory wires that I spliced into then hacking up the computer and harness from a car I parted out to get the connectors and making a nice plug and play setup
