Flynbrd
So the ac was blowing cool instead of cold. I've done ac stuff before so I have a general idea what I'm doing. Anyway I put about 20 oz in (system holds 28 right?) I slowly filled it, the psi slowly climbed from 38 psi to about 44 psi. I was shooting for 45 . I think I heard the emergency blow off for maybe a second. Now the car has pretty much no ac. The car is cycling the compressor on for only a few seconds . The psi on the low is now sitting way high 70 - 80 psi (account of the compressor not staying on I think) I tried to bleed off a few ounces off which did help the numbers a bit. My guess, I hurt the compressor or the system is still overcharged and that's why it won't run the ac compressor for more than a few seconds? Tomorrow I'll hook up the high side if I can find it and see what it's reading. Any theories for the compressor cycling on and off. Also how hard is it to replace? Oh outside temp was in the high 90s
