JWerner2
- Joined
- Mar 27, 2008
- Messages
- 4,935
- Reaction score
- 2
So I decided it was about time to paint the center of my LSE/06 grille.
I removed the grille and took a closer look at it and realized it was a two piece!
Heres what you need to do, very easy!
1. Remove the grille from the car, Duh!
2. Remove the studs.
2. Gently with a needle nose pliers scrape away the black epoxy. Be careful cause there is a tab that is under it that you dont want to break off. If you do you will need to do a bit of extra epoxying.
3. Gently pry the surround off of the center piece.
4. Remove the nut behind the emblem space and pop out the two tabs on top and below the nut and stud.
5. There you go. Now you have the grille apart to do as you wish. You can paint the goddy chrome like I am or you can replace it with some honey comb mesh for the McLaren look or woven mesh for the CDC look!
Just reverse the steps and epoxy it all back together for re-installation.
:Beer
:Beer
