Tach....
SATURN5
Dr. Frankenstang
in the shop
Mine's wonky.
Mine turns CCW as revs come up.
Took it all apart today and resoldered everything, still the same.
Now for the odd part. It will work when it is cold out (30's) until the heater warms up the inside...
Any ideas or should I just find a good replacement?
doesn't hurt to try a new one, then if it still does it try to change out the whole cluster board, and after that a new dash, and after that.... man i think your motor is actully running backwards
I may pull it and toss in some new capacitors. Not a big deal for me to do as it's the stuff I do everyday.
No reason to change the cluster, as the tach goes directly to the main connector via the flex circuit.
Staff online
