SVT Cobra Supercharged 4.6 Factory parts on our engines, can it work?
AbrahamLincoln
Allentown
How easy is it to make the intech 4.6 look like this? Taking factory parts... putting them on our engines?
continental heads (c heads) and a LMS hood plus all the used parts off a cobra, too much work just buy a pro charger
aviator intake manifold? can you use that on the b heads? Does anyone recommend upgrading to the C heads? i see good prices on these factory parts from time to time
as far as i know only thing for b heads are the 98~ish cobra intake, and its a lot of work for little gain N/A
If you are dead set on an SC setup, go with a Vortech S-Trim. Quite a few people have done it, good power gains, comes with install directions, and relatively inexpensive. Do a search, you will be reading for days. Good luck.
I agree, most all of the 12 second and faster Marks I have seen are using centrifugal superchargers. They make bolt on kits in Vortech but I haven't seen a Paxton yet?
Do c heads bolt right on? I;ve read around that with the c heads theres plenty of supercharger options on there for them, way more than the b heads. that being said i want to do this as cheap as possible, not looking for crazy hp numbers, would like to have what the 03 has stock.
so used c heads, used eaton charger. how can a new procharger kit be cheaper, i see those kits are like 3500 dollars?
Did you say C heads??
I seem to have a pair laying around...
It will work, but by the time you're done and have it ready and tuned I promise it will be over 3500.
Now a Procharger kit has every thing you need and you wont have to spend hours searching for used part when you can have new ones at your door in just a couple of days with a warranty.
