93mkviii
I got my alignment done about a month ago after getting new tires but after the alignment, it pulled to the right (just a little). I was going to lower the car anyways so I decide to lower it first and then take it back to suntire to have it aligned again. Now the second time I took it back to them and they ask if I lowered the car. When I said yes, they said we can't align the car or do anything because it has been lowered. They did check it though and said the alignment was fine. Now when I got back in the car, it would go straight but my steering wheel was tilted to the left when the car is going straight. (I don't know how this happened when they didn't do anything to the car except put it on the machine and checked it). The car now does not pull to one side but the steering wheel is tilted when its going straight.
Today I took it to a different suntire but they said the same thing "since it was lowered, they can't do anything about it". (apparently they called the original suntire where i had it done originally for this info). I called the original suntire and ask why lowering the car has anything to do with my CAR'S STEERING WHEEL BEING TILTED. His answer to everything was "toe angle". He also said I had my car lowered the first time i came in, which I DID NOT. Now to my knowledge, even though I have not searched, toe angle is the tire being tilted inwards or outward. WHY can't they keep the steering wheel straight as they straighten the tires? They use a arm like thing to hold the steering wheel straight, so I am guessing they messed up on that part when they "checked it" the second time I took it in.
Has lowering the car given you guys this much trouble? And can someone explain all this alignment stuff so I know when I talk to them. From what I understand, they just need to keep the tires straight and keep the steering straight, RIGHT?
