DFlaJax
Any suggestions on why after coasting above 40 mph and stepping on gas even lightly to maintain speed, tranny shifts to 3rd momentarily before going back into OD? Even downhill?
Sure its downshifting and not just unlocking the TC?
No its not. Its steady state slip and based on load, temp and throttle position. Ive read the stock tune for hours on end and there is no command to fully lock the TC in fourth based on speed.Has to be it most likely because TC lock up is at 39 mph.
Ive only read the code for 96-98 patterns and then for auto Mach1s (no steady state slip) and that of Marauders to figure out what I wanted mine to do. None of them command a lock in fourth at 39 mph. Its closer to 60 and still allows for some slip except on the Mach1.
Now if you are going under 60ish and not on the throttle then the RPM will go down to what the RPM would be if it were locked. Then when you push the throttle a little it will slip the TC and climb several hundred RPM and then to a partial lock after it sees it dont need so much slip and then do a full (almost full) lock when at the computers target speed. That could feel just like a downshift and then upshift.
Its like when Mikes car was at the track and he thought it was upshifting then downshifting then upshifting again on the big end of the track but it wasnt shifting, it was locking then unlocking then re-locking the TC again. I think his issue was the fact his hi-po TC cant do a partial slip and am digressing from the point of this thread........ :lol:
