Strange power loss
Lincoln LS
  1. Corberg71
    Corberg71 New LVC Member
    6
    Oct 6, 2018
    Portland, Oregon
    Hello, I’m brand new to the forum and was looking for some advise with my 01 LS V8. So when I take off from a stop and give a some more throttle than normal the car falls on it’s face. Cuts out and sounds terrible. I’m don’t know these cars that well. So any help would be greatly appreciated
  2. joegr
    joegr Dedicated LVC Member
    18,779
    1,224
    Dec 10, 2005
    Gulfport
    Well, the first thought is always marginal COPs. However, it could be something else. Is your check engine light on? The first step is to pull any and all DTCs (Diagnostic Trouble Codes) from the car using a Ford specific scan tool. The lowest cost one that I know of is Forscan, but there are several others too.
  3. Corberg71
    6
    Oct 6, 2018
    Portland, Oregon
    Ok thanks for the info I’ll check that out
  4. Michaelait
    Michaelait LVC Member
    24
    Oct 4, 2015
    Oxnard
    Yes, new COPS and plugs. On an LS they must be pristine.
  5. Corberg71
    6
    Oct 6, 2018
    Portland, Oregon
    The coils are somewhere around $350-$400 aren’t they?
  6. joegr
    18,779
    1,224
    Dec 10, 2005
    Gulfport
    Yes.
  7. Corberg71
    6
    Oct 6, 2018
    Portland, Oregon
    So I replaced the coils with OEM Motorcraft coils and plugs. I still have the same problem. One thing I noticed is the traction device light is on all the time. Would that possibly have something to do with my power loss?
  8. joegr
    18,779
    1,224
    Dec 10, 2005
    Gulfport
    Yes, it could be related. Are there any other conditions/symptoms/warning lights that you haven't mentioned?
  9. Corberg71
    6
    Oct 6, 2018
    Portland, Oregon
    Yes actually when I’ put my foot into it a little it’s kinda falls on it’s face. Also it sometimes has a rotten eggs smell
  10. joegr
    18,779
    1,224
    Dec 10, 2005
    Gulfport
    Oh well, then I think we have the answer. Clogged catalytic converters, probably caused be prior misfires from bad coils.
    You can unscrew the forward two O2 sensors (temporarily) and take a test drive and see if the power loss is much better. What you are doing is relieving exhaust back pressure by letting exhaust escape from the holes that the O2 sensors are normally in.
  11. Corberg71
    6
    Oct 6, 2018
    Portland, Oregon
    Thank you very much. You’ve been a huge help
  12. NorCalNorse
    NorCalNorse New LVC Member
    8
    Dec 3, 2018
    Moraga, California
    I replaced my coils about a year ago and found a full set of 8 for only around $90.00 on line. Years ago they were VERY expensive. But now you can find great deals online. My thought is that there were a lot made of these particular styles at one time, and now sit in inventory since they are not sold as much as they used to and are obsolete (meaning newer cars use newer coil designs etc) thus the good deals available.
    • Disagree Disagree x 1
    • joegr
      18,779
      1,224
      Dec 10, 2005
      Gulfport
      You can get them for cheaper than that, but you shouldn't. You could cost yourself some very expensive catalytic converters due to the marginal nature of the cheap coils. So far, the only safe bet we have found for coils is the $50 (each) Motorcraft coils. The last set I bought has gone well over a 100K miles, so it seems like they have finally fixed the epoxy problem.
    • NorCalNorse
      8
      Dec 3, 2018
      Moraga, California
      Well thats good knowledge to have! I would never have thought about - I figured a coil is a coil and would not have thought about the effects bad ones could have on the catalytic converter. Now i wish I could go back and see what brand I bought - I think I bought them through 1aauto.com. Ill pay close attention next time I have to buy them!
    • joegr
      18,779
      1,224
      Dec 10, 2005
      Gulfport
      Check out some of the coil threads on here. Some have been okay with aftermarket, for a while, but others have not.
    Share This Page
