devilchild said:what year and lsc/non lsc?
98LSC32V said:I don't know the specs off hand but I do know they are the exact same specs as 03/04 DOHC motors... Mach 1, Cobra, Maruader, Aviator in 03/04 are running Mark VIII cams!
evillally said:Intake:
Primary Lobe, 196 duration @.050/ 390 lift
Secondary Lobe, 206 duration @.050/ 390 lift
Exhaust: 196 duration @.050/ 390 lift
JC1994 said:If you know all that info, why don't you know the stock cam specs?
JC1994 said:camshaft lift is .393/.393-inch.... according to Muscle Mustangs & Fast Fords. unless the info they printed is wrong. it seems like it may be, cause I don't understand why the Mark VIII would have slightly more lift than the 96-98 cobra engine. .
they arent all the same.98LSC32V said:You can take the info I gave to the bank, it's straight from Boss 330.
