Stock cam specs
i do i think.. let me go look for them.. i got a print out from a mechanic friend for all engine specs..
nope.. the ol' lady threw them out... ill see if i can get another copy today when i see him
I don't know the specs off hand but I do know they are the exact same specs as 03/04 DOHC motors... Mach 1, Cobra, Maruader, Aviator in 03/04 are running Mark VIII cams!
not at all
the mach one has a diffrent intake cam, its exhaust cam is from a 5.4 truck, the cobra is diffrent, they are built arround low end torque, and the aviator is also diffrent.
Intake:
Primary Lobe, 196 duration @.050/ 390 lift
Secondary Lobe, 206 duration @.050/ 390 lift
Exhaust: 196 duration @.050/ 390 lift
evillally said:
Intake:
thank you very very much.
JC1994 said:
If you know all that info, why don't you know the stock cam specs?
even steven hawkings does not have all the answers.
camshaft lift is .393/.393-inch.... according to Muscle Mustangs & Fast Fords. unless the info they printed is wrong. it seems like it may be, cause I don't understand why the Mark VIII would have slightly more lift than the 96-98 cobra engine. they say the 96-98 cobra engine has .390/.390 lift. so evillally is probably right. my info came from a MM&FF article on 4.6 DOHC's March 2003 issue. it included all years from 93-03.
You can take the info I gave to the bank, it's straight from Boss 330.
JC1994 said:
camshaft lift is .393/.393-inch.... according to Muscle Mustangs & Fast Fords. unless the info they printed is wrong. it seems like it may be, cause I don't understand why the Mark VIII would have slightly more lift than the 96-98 cobra engine. .
auto vs manual would be my guess, if there is a diffrence between the early cobra cams and the mark.
they arent all the same.
and the last piece of the equation, does anyone know the lsa on them?
03-04 OEM heads use the intake cams from a 4v Navi (99.5-2003) and the exhaust cam is from a 96-01 Cobra (.394" lift for both int/exh, 184 deg intake @ .050, 194 deg exhaust @ .050). The 03-04 intake cam is entirely different than a Mark VIII intake cam. Exhaust is close, if not the same. But all 03-04 4.6 4v cams are in fact the same.
