the same exact thing to the T happened to my mark. I took it to a trusted mechanic and he tested it for head gasket and that wasn't the problem. In the end all i changed was the thermostat cause when u start to over heat each time you damage your thermostat. the crazy thing is that i think the only thing it could be is that the coolant system on the mark is a B*tch to get air out of. I had it at my mechanics place and was working on it with him and he had a pressure pump tool that could be screwed onto the resovoir and put the system under pressure. it took alot of pumps, which is a sign that there is alot of air in the system. after that we took it off, and made sure that the funnel was higher then anything else and filled it back up... the crazzy thing is.. that when it was screwing up... the system wasn't holding pressure... now it is. and is fine... it is running warmer then it did before sh*t hit the fan, but it isn't goin into the "O" on my temp guage on my instrument cluster. I'm goin to have the whole system flushed and see if that cools her down anymore. even though she is holding pressure now. when mine would say low coolant on the display... it was after my system had pushed an air bubble right out through my resovoir cap along with a ton of coolant... thus making the system low....
