lsc 98 f100
What is the life expectancy of a mark starter?I know that starting the vehicle more than twice during one day will lessen the expectancy. Any ideas ?
I just replaced my 1993 one couple months ago. I think it was my fault I had the car under cover for 2 years never touching her. When pulled starter there was water on her so I think snow was getting to starter. I went to boneyard and picked up a real Ford starter for 40 dollars. I also leave the top bolt out with no problems. 109K
We called that the courtesy bolt at the dealer. You did the next guy a 'courtesy' if you left that bolt out.
One of my bottom bolts was seized and f-ed up the aluminum when I pulled it out. So now I have a bolt with a washer and a nut on that one.
As for replacing, I always buy starters and alternators from NAPA, I've had really good luck and most of the time it's lifetime as long as you keep the receipt.
