So ... bad pressure sensor?   That's the item at the back end of the rail?
			Had to borrow a valve stem remover before I was able to get a measurement.
Amazing - as my wife cranked and engine started the pressure got barely to 10 psi.  Then quickly went back to zero as engine stalled.  I know both of those results are bad.  Remember I was able to get the car started and stay started by jumping across the fuel pump terminals.
The fuel rail pressure sensor, shown below, tells the computer what the fuel pressure is so the computer can cycelt the fuel pump on more or less to gain or decrease pressure.
Tried to get a V6 pic but wasn't able to copy and paste but they're all over the web...you should be getting at least 32-65 psi when engine is running
At 32PSI your still within specs on the fuel. If you want to try and bring the pressure up more then change the fuel pressure sensor and filter.
