I used white lithium grease spray and spayed the HECK out of every visible aspect I could of top and bottom rear hinges. Still I get a very noticeable creak when opening/closing either of the rear doors. Anyone had this issue and if so..suggestions?
yeah i had that problem since i washed my car in a self service and sprayed water there.
i used a lot of soapy water and a brush to take out all of the grease or dirt, i had carbuclean so i used it as a high pressure spray to make it to the deep where the brush coulndht get lol then i cleaned it again with clean water and used a lot of wd-40 it might be the best lubricant
Your doors will be louder than ever from using WD40, once it completes drying out your hinge. It is not a lubricant.
WD-40 is Water Displacement Formula # 40... while they claim it has over 1000 uses (including a treatment for arthritis), it's not necessarily a lubricant.well its been more than a year and i still dont have any creack, sound or roughness. and you are wrong, it is a light lubricant and its useful as a residue cleaner, maybe in my case the sound was created by accumulated dirt. that was my suggestion and it worked so let him decide that
