Sport and non-Sport?
Lincoln LS
  1. AmsterDutch
    AmsterDutch Dedicated LVC Member
    1,043
    170
    Jul 9, 2017
    Midwest
    This subject has been covered a ton on the forum but I'm still confused...I have the leather shift nob and no-plastic chrome on bumper but I'm almost positive when looking up my cars VIN # on Etis ( When you could without making a profile and adding email) my car was listed as the base and not the sport....am I not reading the Etis report correctly are all Lincolns on Etis called the base?...I'm always looking at Lincoln LS's for sale and notice that many Lincoln LS's have this wood grain shift nob and chrome bumper ...so again my question is ...How do I truly identify if I have a sport or non-sport? Thanks
  2. joegr
    joegr Dedicated LVC Member
    18,890
    1,261
    Dec 10, 2005
    Gulfport
    It's sport or premium sport, if it says "special" under suspension.
    It's sport or premium sport if you have select shift.
    It's sport of premium sport if you have an oil-to-water cooler.
    It's not premium if you don't have wood grain inside.
  3. Robb15033
    Robb15033 Active LVC Member
    51
    5
    May 12, 2018
    Virginia
    Yeah, Sport is 17" wheels and struts
  4. jgscott
    jgscott Well-Known LVC Member
    354
    7
    May 4, 2008
    Atlanta
    What year is your car?
    And the Trans shift gate is a key also.
  5. Robb15033
    51
    5
    May 12, 2018
    Virginia
    I just purchased a Premium Sport, it has the leather shifter, struts, select shift, 17” wheels, 3 cooling coils if i saw correctly, and a bunch of buttons i still have not figured out.
    Sound Correct For Premium Sport?
    Thanks
  6. 1LoudLS
    1LoudLS Dedicated LVC Member
    9,880
    342
    Mar 31, 2008
    Ann Arbor
    Do you have wood grain on the dash?
  7. Robb15033
    51
    5
    May 12, 2018
    Virginia
    Yes, wood grain on dash
  8. joegr
    18,890
    1,261
    Dec 10, 2005
    Gulfport
    Probably so then.
    Are you talking about the message center buttons (fuel, setup, status, reset)? That's on all V8s and no V6s.
    What do you mean by "3 cooling coils?"
    • Like Like x 1
    • Robb15033
      51
      5
      May 12, 2018
      Virginia
    • Robb15033
      51
      5
      May 12, 2018
      Virginia
      I had go remove the plastic cover under engine, while peering up i saw more than two coils. One of which was greasy and dirty. I had to clean all the coils.
      Reason for looking was because i pushed a button and display went Red and started a diagnostic test. I had to verify power to altinator ...
      Need an owners manual.
      Yes, it is the 3.9L
    • Robb15033
      51
      5
      May 12, 2018
      Virginia
      Reply below, sorry.
    • Robb15033
      51
      5
      May 12, 2018
      Virginia
      Quickly assumed, radiator, condenser,oil or trans cooler????
    • joegr
      18,890
      1,261
      Dec 10, 2005
      Gulfport
      There is the AC condenser, then the combination cooler (transmission and power steering) and then the radiator. This is all the same for base, sport, premium, and premium sport.
      What display went red? The message center can be green only.
      What year?
      Owner's manuals are here: Lincoln LS Owner's Manuals
      2001 is close enough to 2000, 2004 is close enough for 2005 and 2006.
    • Robb15033
      51
      5
      May 12, 2018
      Virginia
      Thank you for clearing that up.
      I have had the car for 2 weeks. Display behind wheel to right i believe. But i am 100% sure it was red and it was firing off messages regarding current mechanical conditions. It paused on “Low Battery Voltage”, and i had zero volts to alternator for about ten minutes, battery had 11 volts. By the time i put the undercarraige cover back on, the battery was up to 13 volts again.
      Thanks
    • joegr
      18,890
      1,261
      Dec 10, 2005
      Gulfport
      How about a picture of that, because that would be non stock.
    • Robb15033
      51
      5
      May 12, 2018
      Virginia
      I hope to never see or have it happen again but will definitely take a picture if it does.
      FYI: It was displaying very detailed diagnostics on oil condition, oil filter, battery volts, every single light bulb, i pulled over, so i was mostly concerned with it stopping on “Low Battery”
    • joegr
      18,890
      1,261
      Dec 10, 2005
      Gulfport
      The message center goes though a list of things if you press "status", however this list does not include "battery volts", "oil filter", and so on. It does have a percentage of oil life left (estimated) and a percentage of AC filter life left (not oil filter), and it does cover several bulbs, but not nearly all of them. And it is a single color (green) vacuum fluorescent display that can not change color. I forget which status it ends on. The multi-status display with oil life and such does not start on its own, the status button has to be pressed. A single status message indicating a problem can appear on its own with no buttons pressed.
      Example: You could get a message saying "change oil soon" and later a message saying "change oil now", but you have to press the button to get a message saying oil life 1%.
      • Like Like x 1
      • AmsterDutch
        1,043
        170
        Jul 9, 2017
        Midwest
        Yeah I agree, it would be nice to see your LS post a pic and let's see the interior it sounds very strange to say the least that your message center is "red" it has always showed green in my first Gen 2001....this would be very interesting if your lighting is different than green and if all those component checks are showing up "red"
      • joegr
        18,890
        1,261
        Dec 10, 2005
        Gulfport
        Maybe I've been to gentle on this. I call BS. There's no way its a factory two (or more) color display. It is possible to change the color of the whole display, all the time, by changing the filter, but going from the native blue-green color to red would leave it very dark.
        Also, he is calling out messages that do not exist.
        • Agree Agree x 1
        • Robb15033
          51
          5
          May 12, 2018
          Virginia
          Yes, Thank You.
          I scrolled through the status display today.
          I appreciate the explaination.
          Yes all displays are green.
          I very well could be mistaken on the message “Low Battery Voltage” being green and not red.
          Thanks again for all the info!
          Much love my LS brothers!!
        • FDR
          FDR Dedicated LVC Member
          1,775
          82
          Jan 20, 2014
          Central NJ
          All Gen 1s had the same wood trim line across the doors, headlight switch, ignition, and over the glovebox
          Sports had stiffer shocks (and sway bars). The springs didn't change with trim. Still no struts to be found on any LS
          Premium Sports also put the chrome back on the bumpers IIRC
          • Like Like x 1
          • rgorke
            rgorke Well-Known LVC Member
            261
            18
            Aug 5, 2017
            Camarillo, CA
            Not on Gen II. Premium sport has color matched bumpers. The grille and license plate surround are chrome...unless it is an LSE or 06.
          Share This Page
