installing the amp..
1.Run your power wire directly to the battery then work it through a gromet in the fire wall, under the carpet, to your trunk.oh wait the battery is in the trunk..Make sure you have a fuse about 6 in" from the battery.
2.Run a remote wire either off a fuse, or a power wire in the back of your radio.
3. Drill hole for ground, ground wire shoudl be no longer then a ft.
now for the rcas
THe easiest way for rcas is to get a line out converter,because your stock head unit doesnt have the rcas in the back of the radio you can pick it up at best buy for 14.99 or even meijers..
Get the one without the ground wire, otherwise your going to need a ground loop converter..
Splice them directly into your rear 6x9 speakers, directly in the trunk, the wires are color cordinated, so the install will be easy....
any questions feel free to contact me, i've been installin for a few yrs now, I do custom installs as well... Custom enclosures, I also do fiberglass installs.
