The platinum motorcraft plugs that came with these cars lasted for at least 100,000 miles. Why not just use what is recomended?
Is this a problem on our cars? I thought as long as the engine was cold and the plugs only done up to recommended torque all would be well. Surely a plug thats been sat in a head for 10 years plus with 100k on it could pose problems in itself? Just a thought...
Usually overtightning is to blame. However my car had 67k when I bought it and had stock plugs in it. They were so tight to remove I had to use a 1/2ratchet...tight all the way out. Either the stockers were just jambed from being old or replaced and overtightened stock units were put in at some time. After completing the change I knew it was just a matter of time or next replacement that threads would be gone. It shot out one will driving. You don't have to replace the head or even pull it. You can install thread-serts.
On my friends, he somehow dropped the end of the re threading tool into the cylinder so he had to pull the heads, He took them to a machine shop that ended up re threading them too deep into the head. That's why he needed to get another set of heads.
Even so, why take a chance?
The tool I used was designed for it, there wasn't a way to drop the tool in from what I remember. Sounds like a poor machine shop. I did all eight to never have the problem again and they are all the same. I can't imagine comparing the $120-$130 I spent for eight thread-serts to his bill.
Taking a chance on what?
I meant taking a chance on using the copper plugs, having to change them out every year or so. The aluminum threads may become weak. That's what I meant. There is nothing wrong with re threading them if they are done right. The machine shop must have sucked! I agree.
What is the correct torque for our plugs? ive been searching and getting all different specs between 7 and 16 ft/lbs. Also, just been doin some reading on modular fords.com and there seems to be an issue with the early mod heads not having enough threads? 4 threads or something? Ford got legal action took against them by NHTSA? Can anyone shed any light on this?
