Signal Issue
Markviiiedrea
Speed Bump
Bloomington, MN
My right blinker flash's fast like a bulb is burnt out and only the rear right flashes but I checked front and rear right turn signals and replaced all the bulbs. Still got a fast blinker and the front right still won’t signal.....and yes I checked the blinker fluid...any suggestions? Fuses are all good.
Thanks!
You could try a new flasher
getimage.php
I am sure you got one laying around in your parts stash.
Thanks Guys, I know I got the extra parts if needed. I will take it apart tonight. Where is the flasher relay located? Sounds like its coming from under the steering column.
I have some Electrical parts cleaner I can clean all the socets out with too.
Im not sure on the 95, but mine was behind the glove box. My was the same way. It would come and go. I thought it was the flasher but it was the multi switch. When that goes, you will have no signal, no hazzard and no brake light just the 3rd. Brake light.
M ine was the pass side tail lamp the little bulb up in small end - the plastic socket had melted enought to loose contact with the bulb - had to splice in a new socket - lots of wire so easy to do.
Din't get to it last night, had to get my C/C installed. Hopfully look at it tomorrow. TOO DAMN HOT out today to do anything.
I was going to work on my interior too today but its like Africa hot and Viet Nam Muggy. think ill watch HBO's True Blood for a while and sit in the cool air.....did you ever find the flasher relay? i cant find mine either.
Holy Balls! i went outside and almost fell over. whats with the heat and humidity? its like someone opened the oven door. ill take -20 below zero before this crap.
Well todays seems better, I'll be waxing the car up tonight for Car Craft this weekend and I will take a look at it finally.
