jcharb
I need help from someone who knows about transmissions and diagnostics or maybe has had an issue similar to i am having.... maybe a ford tech..
So a few weeks ago i posted an issue that happened from installing the wrong solenoid in my transmission, it's an 03 v6, anyway, fast forward to now, i have installed the correct solenoid in my transmission and since doing so i have the classic E still in my gauge cluster, i don't have 5th gear and i can't switch manually from d4 down to d1, i'm pulling 7 codes related to the fact, which are as follows:
p0743 - TCC solenoid circuit failure during on-board diagnostics
p0750 - SSA solenoid circuit failure
p0760 - SSC solenoid circuit failure
p0765 - SSD solenoid circuit failure
p0962 - PCA solenoid circuit failure - short to ground
p0966 - PCB solenoid circuit failure - short to ground
p0970 - PCC solenoid circuit failure - short to ground
These are my codes, if anyone can help, i love my car, but i want to burn it right now lol, it seems the more i touch it the worse it gets. So any help is greatly appreciated since i'm not to versed in transmissions, since i used to have manual cars. thanks
