LunaEros
Ok. had a higher pitched rattle quite bad coming from the front on bot sides over even small bumps in the road which sounded a lot like this...
So I was told by a mechanic who has worked on more than a few of thes and he thought it was in the strut. So I got some good condition used strut assemblies from a guy in Texas that parts out LS's and S-Types. Put them in and the noise was a little less but got came back loud after a long distance trip. I also had along with that rattle a lower pitch kinda thud type rattle/rumble(?) from the front mostly left. I had them put it back up to look for it and the only thing he could find is the lower control arm bushings seemed to have more movement than normal. So I got two new arms with bushings and just had them put in. The high pitched rattle seems to be gone but the low pitched rattle/rumble is still there. He said that it's probably the struts. Specifically the strut plate.
I said I just replaced them to which he says yeah but you got used ones, right? I said yes but they were in better condition. He said they probably weren't much better because what happens is that when they get a lot of miles and time on them they have a bearing in them that gets worn out as well as the rubber in them and can make all kind of noises.
Is there a bearing in these? And can they make a low thud rattle/rumble or high pitched loose rattle sound if they're worn out?
