solja.b
Does anyone know anyone that can flash my SCT chip to a '94 lincoln. I want all the options done correctly. I have some mods but nothin major like the differential or supercharger.
I have screemin demon ignition and live wire spark wires. True dual 2.5" exhaust with 1 x pipe and quad tips.
I just want to get my car running better to do a few tweaks before I go dyno. I think modifying my exhaust made my computer get bad readings from O2 sensors and the IMRCs are acting up.
Anyway, please let me know if anyone can help me. I don't want to spend too much but I would be willing to go in the $50-$100. Anything more I'd have to maybe go ahead and just get the DYNO guy to do it all for $300.
I got this chip used and it is currently programmed to a 88-91 Mustang.
Change spark to use premium gas and gain more power
Adjust commanded Air/Fuel ratio for more power
Transmission Shift points altered
Transmission Shifts firmed up
Torque reduction decreased during shifts
Torque converter lockup changes
Ability to eliminate rear O2 settings for aftermarket exhaust on ODB-II Cars
Boost bypass reduced or eliminated during shifts
Shift light raised or removed
Rev Limiter removed
Speed limiter removed
Electric fan settings adjusted
Adaptive learning optimized for better economy and drivability
Knock sensor threshold adjusted on cars equipped with knock sensors
Octane pin can be setup to compensate for race gas when removed
EGR disabled
Chip can be programmed for different injectors or a different MAF
Idle in Neutral and Drive adjusted
IMRC Control, can be deleted or adjusted on cars that have IMRC
Rev Limiter removed
EGR disabled
