Replacing door cable - how to??
67Continental
Montreal
I checked out my CD manual to find out how to replace the door cable inside my driver's door - but there was nothing. Does anyone have a how to? Has anyone done this before?
Should be in your manual, dosn't sound fun,... says, "The inside handls, cable, latch assembly, power actuator rod, lock cylinder rod and lock/ unlock rod must be removed as a unit"...
01-14A-5
01-14A-5
damn. all I can find is latch removal ,and outdoor handle removal, there's nothing specifically about removing the interior handle, or how the cable is attached to the latch / lock mechanism....
No, I don't see anything on the cable itself, sounds like you might need the latch loose though...
I am hoping that once the latch is loose, I can slide it out or something....beyond that, not a lot of space to fool around in inside the door. I would love to know what size bolts I will need to replace the rivets I have to drill as well, to get the inner door handle out.
once you get the handle off the door look at how the cable is attached its simple to do but hard to explain, the other end on the latch is attached the same way, its not hard dont worry and you will be fine
I'll take some pictures of the removal process when I pull your part off ot the door. You want tme to print and package them with the part, or e-mail them to you?
Remote Control Assembly—Inside Handle
Removal and Installation
Remove front door trim panel (23942) and watershield.
Remove rivets retaining front door latch remote control and link (21818) to front door (20124).
Disconnect front door latch remote control and link from front door latch (21812).
To install, reverse Removal procedure.
dont know if this helps you at all.
either one would be good, thanks - I usually take the laptop out with me to the car when I do my repairs - I really appreciate it :)
Is there any way I can use get a bolt size to replace the rivets with? They are the one thing that doesn't seem to have a number associated it with it in your diagram.
I would just get a bolt slightly smaller than the bit you use to drill the rivets out. Just make sure it's not long as hell so it does'nt interfere with other things.
